[URL=Custom lights]http://www.angelfire.com/fl5/import/indigloneedles.html[/URL]
well someone gave me that...and while i was wiring my LEDS in the dash i took of the cluster and took it apart and sure enough i see where the LEDs are...but just wonderin if this will work...thanks in advance
-Ozzie
My Bad.....thought i was on my reg. Forum
Click heRe
-Ozzie
Since you have to remove the needles, NO, it wont work. You remove them needles, you cant put them back on.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Lawnmowerracer wrote:Since you have to remove the needles, NO, it wont work. You remove them needles, you cant put them back on.
what about a 98 cavalier?
say you dont take the needles off and just go behind and take out the factory lights and put in LEDs. that would do it right since the needles are pretty much clear.
on a 95-99, this would probably work, since you can remove the needles without screwing up the gauges.  on a 2000-05, you can't safely remove the needles without breaking the gauges.
Those are the most badass looking gauges/needles I've ever seen!  lol.
i am sure you can take the back off of the gauge cluster and change the lights, i would go get a used gauge cluster from the junkyard and do it to that one, to test it so you dont screw up your cluster.
