i have used three coats of  krylon fusion on the interior door panels and sanded using 320 grit sandpaper, yet i still can't get that fiber glass look on the finish. What gives?
did you sand teh door panels with 80 ,120 and 240 first to get rid of all the little sqigalies in the door panels? do that then primer it sand again with 400 then aply fusion. i did that and it worked great..
mind you its not finished but you should get the idea...
"Boost tuning"....... have you had your 8 PSI today?
future name of the winter shop!!!
if your using the clear coat that your supposed to with the krylon fusion then that's why you won't get that nice glass look. When I used the right clear coat that you have to use for the krylon paint it left it all spotty clear. Won't use that paint again.
