im going to be installing this bezel this weekend and have not even looked at how the cluster is in my car ( 02 sunfire ) .
has anyone else installed one before? is there a how to?
thanks in advance.
heres a pic from e-bay of the bezel.
My car was made with wrenches, Not chopsticks.
J TO ENVY wrote:There is basically three ways you can install it:
1.) Put it between the gauge face and the clear plastic cover which has the factory bezel attached to it (if you do it this way, not much of the new bezel will show)
2.) Remove the clear plastic cover and install the new bezel on top of the factory one
3.) Use a dremel to cut the factory bezel out and set the new bezel directly on top of the gauge face
Hopefully this weekend I will be doing the third option. I will be sure to post pictures. I hope it works.
THANKS!
but how do I get the gauge cluster out?
  I have not looked at it yet so if thats a really dumb obvious question sorry!  lol
^^^ thats real easy just take off the dash top and theres 2 plain view screws that unscrew the cluster from the dash...then just unpplug it and take it out
Take the top of the dash off( one screw in the drivers dash end, I forget how many in the glove box, but when you open it you'll see a row of screws at the top of the glove box, look in the glove box thru the hole in the top and there are another two swrews , one in the pass dash end) pull up on the dash, there are clips holding it to the radio and cluster peice so just pull up. Then there are three screws that hold the radio/ cluster trim in place. Be carefull when taking this peice out. You don't want to break it. After that's out of the way there are two screws holding the Cluster in.
I my bad. Didn't realize you got fire.
