my cavi is falling apart were your elbo rest and i dont know how to reglue it back on what should i do for that
allso were can i find some nice gages for like vlots or how much oil i have left somthin like that
Well you obviuosly quite new to the game.
Autometer, Datoka digital, and Sunpro are respectable companies to get gauges from.
A volt gauge tells you how many volts (duh) your running when your car is on.
An oil pressure gauge will tell you if your oil pressure is to low or too high. Its a good way to diagnose some problems, as for oil being actually too low, there are 2 ways to check.
1) Check the dipstick
or
2) Wait till the idiot light comes on.
As for your arm rest, There are 2 bolts under the arm rest itself, they are 7mm bolt heads, just reinsert  bolts, and tighten.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
allright thanks man but my car dont have an oil light for some reason and the actuall skin of the my arm rest is coming undone
Take the piece to an interior shop and have it redone, or take the door panel off yourself and try fixing it from there. There's a post on this site that gives you every detail toward taking the panel off. Look around.
http://img142.imageshack.us/img142/3355/cav45oq.jpg
no its not the door pannel its the pice that sits right next to my shifter
Bruce Fulk wrote:Take the piece to an interior shop and have it redone, or take the door panel off yourself and try fixing it from there. There's a post on this site that gives you every detail toward taking the panel off. Look around.
if it wasnt the door panel then why did you talk about removing it???
<a href="http://www.liquidgeneration.com" target="_blank"><img src="http://www.liquidgeneration.com/quiz/images/bat_freeze.jpg" border="0"></a>
