Red X's
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Ya, I think a dark hunter green would look good!
Yeah, I was thinking about having a shop spray the same color as the exterior.  What do you think it would run me if I did all the prior prep work?  Do you think I could find a color in a spray can that would match well?
u could find something somewhat close but it will never match from a can.
cost will vary depending on what u do yourself, the amount of work your doing, and the guy whos painting it,   when i did my parts, i did all the sanding myself.  took it to the painter to prime, then i even picked the pieces up to wetsand the primer, before he sprayed them with paint. this kept costs lower.
http://www.flickr.com/photos/sndsgood/   https://www.facebook.com/#!/Square1Photography
Just out of curiousity, what all did you have painted and around what did it cost you?  I was planning on doing all of the sanding and everything myself, and just having a shop spray the coats.
