hi. how the hell do you get the sunroof cover out of the car? im reupholstering it
thanks
It's the car right?.....Chicks dig the car.
take the headliner off and then it should come right out.
i have the headliner out . i still cant figure out how to get the cover out. i dont see any way how it could just slide out, but im probably a moron.
the slider piece that hides the sunroof , you pop the sunroof open and there is 4 clips you need to release to pop it out
dont open the sunroof just vent it and you can see the clips
thanks! ima try now
blasted!!!! didnt work. i dont see any clips. oh well, i have the headliner reupholstered and back in. the light gray sunroof cover doesnt look too bad with the black headliner, but would look better black.
thanks man!!!!! ill give that a try tomorrow nite. good to hear that i dont have to take the whole healiner out again!
oh wait, nevermind, yes i do. lol!
Do you have a stock power sunroof installed?  Like 97Cavie said but they are not clips.  There are 4 spring loaded pins that hold the cover in the track.  Just vent the sunroof and slid the cover all the way forward.  You should see 2 black pins with springs on each side.  Just use a screwdriver and push the pins into the cover on at a time.  You can then push up on the cover after each pin and pull the cover thru the vented sunroof above the car.
 I had to remove my a couple days ago because something was stuck in the roof and wouldn't allow the cover to open all the way.
Ryan
push pins , clips same kinda thing , they are very obvious as to what they are though
Juggalo wrote:Do you have a stock power sunroof installed?  Like 97Cavie said but they are not clips.  There are 4 spring loaded pins that hold the cover in the track.  Just vent the sunroof and slid the cover all the way forward.  You should see 2 black pins with springs on each side.  Just use a screwdriver and push the pins into the cover on at a time.  You can then push up on the cover after each pin and pull the cover thru the vented sunroof above the car.
Ryan
thats the easiest way to do it. u can have it out in about 30 seconds.
http://www.flickr.com/photos/sndsgood/   https://www.facebook.com/#!/Square1Photography
thanks for the help!!
