it goes all the way up to where it should start going down and just stops. theres nothing in the way that i can see and i oiled everything.
when its closing it seems to be crooked, could this be the prob and how would i fix this?
Thanks in advance for any help it is greatly appreciated
you'll probably have to pull down the head liner to get to the motor. after you get to it undo the 3 star bit screws(i forget the size, t20 i think). tug on the motor a liitle bit to get it to come down(becareful you dont pull out the wires). then slide the roof all the way open by hand, and with the motor still down hit the switch to make the motor in the all the way open position. then put the motor back in tighten the screw, but dont put everything back together yet, test it out first!!
the same thing happened to me and thats what i did to fix it and i havent had any troubles with it since, and that was last summer. i hope it helps
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
THANKS i'LL TRY IT IN THE MORNING
