ok  you can see in this pic that i haven't painted the strip by the winshield and the lower half of the dash (glove box, understeering wheel)
How do you paint these/take em out to paint.
Thanks all!
http://www.cardomain.com/ride/857357
I obviously had my dash and everything else taken apart. We had the stereo out and climate control and the airbag off... then attempted the steering wheel... can you get out the bottom half of your dash or do you just paint it in the car. And how do you get that top piece off cause it looked like it was part of the lower dash
wow yours inst cracked!! what year is your car?
Im guessing it's a 2000-2002...regardless Im jealous...mine has been cracked since i bought it
To get that piece out I am pretty sure you need to take out the
entire dash.  EVERYTHING!  Down to the firewall pretty much.
Jay
One huge aluminum wing - $200
More vinyl graphics than your ride can handle - $150
Decals for products you don’t even have - $10
500lbs of Car Audio equipment in the trunk - $1500
Getting slaughtered by a KIA - Priceless
The big noticeable crack thats been there since i got it is right in front of the defroster vent...I had a friend with a 2000 sedan and his dad had a 2001 sedan, both cracked..i have a small crack in mine in front of the air bag cover on the dash....yet my mom's 96 cavi coupe has almost 165K miles and no cracks
one of the J-Body Companies on here sells a fiberglass piece that goes over it. I wanna say it's Winks but i'm not sure. It's one alternative to having to take your WHOLE dash apart.
SO EVERYTHING!
Those 2 parts that you have not painted yet are the same piece- as you mentioned above.
When they say the whole dash, they mean everything- airbags, steering wheel, Hvac ducts etc etc...
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
-unplug the negative side of your battery
-pull the airbag fuse out
-take off your dash pad
- take off your bezel
-take our your stereo
-take out the HVAC
-take out the instrument cluster
-take off the steering wheel ( driver side airbag will come with it)
-take out the passenger side airbag
-remove A/C / Heater ducting
after that you should have a huge piece left which covers the lower dash and the piece by the windshield... unbolt every gold bolt holding it on and pull it out...
have fun..... i have done this 3 times already....and i will not do it again as i have my sunfire interior in my cav now
yes i was winks that was selling those, but if i remmeber correctly some people were having fitment problems and such
Jess Black wrote:I obviously had my dash and everything else taken apart. We had the stereo out and climate control and the airbag off... then attempted the steering wheel... can you get out the bottom half of your dash or do you just paint it in the car. And how do you get that top piece off cause it looked like it was part of the lower dash
sounds like you were pretty close there, if you had pulled the steering wheel off. popped off the plastic vent ducting and then just followed along the edge of the dash removing the screws you could have popped it right out.
http://www.flickr.com/photos/sndsgood/   https://www.facebook.com/#!/Square1Photography
ya I was very close to getting it off, but we couldnt figure out how to get the steering wheel off and it was roasting in my car and I was in the mist of painting on my only 4 days off in 3 weeks.........i gave up and just painted what i had! haha.
remove as much as possible. tape off everything else, paint
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
Nice interior. Don't know much about takin those parts off but waz up with the stupid crack!! mine has it too and it's a 2000 sedan. I bought it used w/ 35K miles on it was already there. My friend has a 2001 coupe w/ 51K miles on it and no crack!!!
stock '00 2200 cavy
the crack is normal. it's due to sunlight and flexing. my 99 has two cracks (there when i bought it) but my ex-g/f's mom's 96 cavi doesn't have a crack. it's just luck of the draw i guess.
SO EVERYTHING!
