I did a power window conversion on my sunfire.  Will a panel from a sunfire with power windows fit, or will the crank stick out too far?
Beat it like it owes you money
how hard was it to convert, did you use stock pieces?
Celebrating 4:20 Just a little early!
yes they will. If you dont want to spend the money on new door panels, go to a1electric.com, if you search around you'll find caps you can install to cover up the whole, you'll hardly notice it.
found this link for the caps
just put a tweeter in the opening
<a href="http://www.liquidgeneration.com" target="_blank"><img src="http://www.liquidgeneration.com/quiz/images/bat_freeze.jpg" border="0"></a>
My car was broken into and my door panels were trashed.  I just wanted to know if they fit, thank you all for your input
cmunn99gt wrote:yes they will. If you dont want to spend the money on new door panels, go to a1electric.com, if you search around you'll find caps you can install to cover up the whole, you'll hardly notice it.
I retract my statement. what kit did you use? if it was an OEM type kit, then the door panels will fit. if you used the SPAL type kit, where you put a piece around the window crank, the panels wont fit. you need to use the older panels, and put a cap on them that would have come with the window kit, if that makes sense...
I used the spal kit.
then no the door panels will not fit
