First off, I did a search and I found nothing.  I cannot figure out how to get the center console out of my 02 Cavalier, and any help would be great, it is the last piece that needs to be painted.
Thanks in advance,
-Paul
4 bolts.
1 in the foward map tray.
1 Just under center switch pop out piece.
2 inside the Main holder section, all the way at the bottom.
Remove shift knob, and pull ebrake up.  Tilt back of console up, then pull front up to clear everything else.
If it wont get passed the shifter, like on mine, Put  the car in drive, and keep foot on brake, then pull console up.
Dont forget to put car back in park.
http://members.rankmyride.com/djtorello
I have an auto trans. how do i get the shift knob off?
there is a U clip in the front of the shift knob
You must not have searched hard enough because i just answered this last week.
Irate wrote:there is a U clip in the front of the shift knob
if there isn't a clip then it's glued on.
SO EVERYTHING!
easy stuff. whenever u need to take something out and don't know how, try looking around it and see if there are any screws or anything holding. It helps a lot!
stock '00 2200 cavy
