Where can I find a Voltmeter and gauge pod and is it easy to install. or are there any easy meteres that can be hooked up on a 99 Z24?
They're all easy to install.  You just hook it into any 12V source and to ground.
Just be sure to make it a switched  source, or it will stay on all the time.
Does it hurt anything for it to be on all the time?
I hooked mine right up to the battery - no bad effects so far...and since I can't actually SEE it on since I'm not in the car, I try not to think about it.
Steve
I got a gauge from somebody that decided not to use it. Went to autozone and got a universal pod. Used lots of heat froma hair drier to shape the pod to the piller. I taped the gauge into the ignition switches yellow wire for 12v source with key on and ground the other wire. Looks good for now and works well.
Blue Cav Customs wrote:Does it hurt anything for it to be on all the time?
I don't guess, as long as you have a good battery.
Crystal(CrazyCavGirl) OR Jacob wrote:Blue Cav Customs wrote:Does it hurt anything for it to be on all the time?
And if it's draining the battery...  well at least you'll know as soon as you get in the car and see what the gauge says.
