hey whats up guys i wanted o know if you guys could post pics of the interior of your car if its painted so i can get some ideas of how i want to do mine
Here ya go.
Expect to see 75% of the white to disappear over the winter. All peices done in Dupont Chroma Premier by the way.
Proud member of
JBOK (J-bodies of Kentucky)
is that fiberglass or is it just paint and how much did you spend?
I believe he color matched to the exterior color and sprayed over the sanded down panel.
jovan joseph wrote:is that fiberglass or is it just paint and how much did you spend?
The only fiberlgass in my interior is where the gauges are where the HVAC once was and where the seatbelt holes were shaved. The rest has just been lightly sanded with 180 and I let a high-build urethane primer do the rest. Price wise, I can't really tell ya, I had alot of paint left over from the car being re-painted so I used some of it. The most I was out was around a $100 for an HVLP spray gun to spray it with. I say paint and everything I made it under $200. But I did get the paint at 70% discount.
Fugitive is right. Its color-matched, then I started at with 180 grit sandpaper, then wetsanded at 220. Laid the urethane primer to fill everything in (about 3 or 4 coats). Wetsanded with 400 then 600. Laid my white primer sealer. Then laid base and clear. Then what runs I had I wetsanded and buffed the panel out.
Proud member of
So do you have to sand everything down before you paint it?  I am interested in painting the inside of my car but i really am not knowlegable on the subject.  But i don't want to figer glass.
hey i want to paint the dash bored will it be ok?
depends on what paint you use. dont sand it unless you remove the vinyl
Interior
what kind of paint do i use if i want to paint the dash bored ????because i have a list of everything  i need i just want to do the dash, i want the whole inside to be painted................ also where can i get custome carpet at and seats and all that good stuff w/ out going out of town
^^^^^^^online, can buy from the comfort of your own home , in your own town
Now, now, Jovan.  No need to get harsh with the other org members.  Even though their responses may not seem so helpful, in fact they are.  You just have to look past words to find the hidden answer.
For the dash, you can use vinyl and fabric dye from Duplicolor, or glass it then use regular paint.  You may be able to get away with reg paint unglassed, however that is not really recommended.  As the dash heats up/cools down, your dash paint will be prone to cracking and peeling.
To expand on Toboggan's answer, unless you know of an uphostery shop in your city (ie, yellow pages), you will need to look online.
Carpet and seats, see if your local auto parts store can special order them for you.  Or, you can check out the group purchase forum, there may be one for seats still going.  If not, check out either
Gravana or
A-Plus Performance.  If you just want a black carpet, check out
JC Whitney.
Or if you want a simple color change you could do like I did and peel the old vinyl off the dash and re-wrap it with whatever color vinyl you want.
Proud member of
so use vinyl and fabric dye for the dash, or glass it then use regular paint
ok whats better to do cause i dont know what to do because i want the dash painted to?
so its just a vinyl paint with clear coats right?
Sanded and Rattlecanned with duplicolor
02 Subaru Impreza WRX Wagon
ok im new to this car stuff what is Sanded and Rattlecanned with duplicolor
Sand paper and spraypaint
