just buy a flip out screen lol
because just buyin a flip out screen would be the easy way out and also nto very custom and since im goin all custom i wanted it custom, lol
That will look good when you get done keep us updated
ok will do guys, anyways i got it in and headunit installed still need to sand and paint but anyways head unit looks crooked but owell its not its just that the dash is angled towards the drive and its not but other than that i love where its at!
Are you fiberglassing the center console to the HVAC/Radio cluster?
no i am not! but its such a close gap that you wont see a difference, will have more pics up tomarrow!
you have a leaf in your car..
anyways it looks messy but so does my little project. Hopefuly later today Ill be done sanding and I can prime it, ill post pics of it in primier. Im sure all of you will looooove it.
Looks like it. Looks like your sanding job will be easier then mine. I just primed and there are still alot of spots that need touched up, and I still have to cut the hole out. Its looking bad ass though, ill post pics later tonight.
jvc...blah, lo0k go0d tho go0d luck
put a 00-05 dash in it , that will give you a bigger radio opening
man thats some gangsta @!#$ i want to see pics when your done
ok to answer questions:
yes face plate is removable
yes i layered th glass just right that it was almost perfect
sanded it all down this evening and then skimmed it again to finish up any inperfections with jelly type resin and then sanded it with palm sander now i just need to hand sand and feather! then prime paint, so yeah its turning out but long process and im thinkin of makin a how to after all this if anyone want to know how then!
only thing left to do is install my switches and it will be done.....
but i will keep sending pics and should be starting on the monitor install this week as well!
lookin awsome...
those first pics did not look that great, just looked like the fiberglass was just miscariously placed there, but NOW,
a lot better....
are you going to keep the kupho;der switches recessed, or are they going to be flush with the rim?
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
i think recessed if they do go in there may put my volt guage there instead though!!!
since the face plate is removeable I would of detatched the faceplate and mouted it seperately from the HU.  just seems like it would of been a cleaner look.  but you're not done yet, I'm sure once you are it will look as good as the rest of your car.
Causa latet vis est notissima
DIY Clear 03+ Headlights
thnx grimor and i was thinkin of that but i cant eject a cd with out the face plate being there because its a theft feature. but yeah it should look pimp once done
to hook up the faceplate, seperate from the head unit, is possible, just gotta take the HU appart, and maybe solder one of those flat wire thingys, and to be able to remove the cd, there should be somekind of plastic tab, that would be easy to rig, so that the HU ** thinks ** the faceplate is attached.
Question what happens when the cd player dies and needs to be replaced?  how hard is that to get out?
'spit chew hits soldiers boot'
"thats a real nasty habit you got there"
"this stuff will make you a sexual tyransaur just like me"
jesse the body ventura in Predator
good question^^^ but um yeah as stated in a above post, i used the headunit install kit to house the headunit, which means the entire thing is removable!! i will have more pics when i get home from skewl everyone, aslo any one interested in a how too???
