does your mom know or is she on vacation? LOL
sorry i cant help i just wanted to be a dumbass
LOL thats aewsome
If my parents had the same car a me i could swap the whole interior and they wouldnt even notice.
good luck on this and i hope someone can help you out.
Well there is a bracket that bolts on using the 2 forward shifter studs that needs to be swapped over as well that has the bolt hole for the front of the console
Then there is a bracket that is held on by the back of the shifter and e-brake handle that woud need to be swapped as well because thats for the screw that is under the window switch, and then the 2 screws in the console itself is the same.
I just swapped in a 95-99 sunfire coupe consle into my 99 cavy along with the entire dash from a 95-99 sunfire, now al i need is a set of 2K+ sunfire door panels and my swap will be complete.
I have my stock 99 cavy 5 speed console for sale if anybdy is intersted?
Mike
1992 GMC Sonoma GT #492.  Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5.  Mods and pics are in my registry.
That pretty much says it all.
Support the site that supports your habit, Go Premium.
yea if it's anything like putting a 00+ cavi center console into a 95-99 cavi it'll fit in but one bolt won't be able to go in and it'll sit crooked.
found that out when i put my 00+ center console in my 99 cavi.
SO EVERYTHING!
J TO ENVY wrote:So, in other words I need the mounting brackets from a '00+? Are the mounting brackets bolted in? How do I go about getting them out of the car? Thanks.
You will unbolt the shifter assembly and the ebrake assembly and the 2 brackets will be under them.  Remove them, and then bolt the shifter and ebrake back down.
But what console are you putting back into your car?
Mike
00+ consoles are the same for both Cavalier and Sunfire... it's only the 95-99 ones that were different between the two models.
The metal brackets are bolted to the shifter/ebrake assembly. You should be able to find them at any wrecker...
...j
when you gonna learn the term -
JUUSSSS DDOOOOOO IIITTTTTTTT
:p:p:p:p
HEy man, thats kewl........  he he, ...your MOMS into moding her car.............  hell yeah....w
hen is she getting nitrous? J/K
i wish my parents could share the same enthusiasm as me in their cars, maybe we would actually have normal conversations !!!
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
J TO ENVY wrote:[quote= 97cavie24ls(JDM&00s/c sedans™)]when you gonna learn the term - JUUSSSS DDOOOOOO IIITTTTTTTT
Hush you!
ummm uuuuummmm
NO
i gotta give you a hard time some how , lol
but really only way to know is just DO IT !!!!!!!!!!!!
