Hey everyone just a few questions.  The Cobalt guages need a switchable light source (IE wired to headlights) what wire is that on the headlight switch on the stering colum?  Also what is a good key on power wire to tap into that could safely supply 3 more guages?
(and yes i did search)
Thanks
Riki
~Riki
SPONSORED BY: No one!
Car Domain Site
For my gauges, I tapped right into the harness that goes into the stock gauge cluster.
Do those need a constant 12V wire switched with the headlights or can you use a dash lighting (voltage regulated by dimmer switch) wire?
i got mine from the dimmer switch
[quote=97cavie24ls(JDM&00s/c sedans�)]i got mine from the dimmer switch
same here...most of the time thats the best place to
run interior lighting from (just my opinion)
Okay this is what i got from the autometer site.
Black= ground
White= + 12v dash
Red= +12v Connection
I'm at work right now so I am not currently looking at the guages or the full instructions.  I'd upload the image but for some reason ImageShack is not working for me (keeps timing out on this network).
So for the dimmer panel, you can adjust the brightness of the guages via the switch and the guages only light when the headlights and sock guages are lit?
~Riki
Car Domain Site
yup
the white wire goes to the dash lights
and like i said i got mine at the dimmer , its usually easier to get to if they left enough wire , you can go through the side of the dash next to the dimmer
go to your parking lights NOT headlights, cust in case.........
your light inside the car come on with parking
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
Okay so here is what i got so far...
Black = ground (Thats easy)
White = Dimmer panel (what wire?)
Red = Still need to find a 12 V source (I'll take a mulitmeter to some wires in the dash)
Now I'm just waiting for this kid to buy my bass so i can get a pillar pod.  He still hasnt sent money.
~Riki
Car Domain Site
if you have multimeter, just check one of the wires in the dimmer, and post the solution
lol smart a$$.  Yea i realized that when after i posted.
~Riki
Car Domain Site
yeah well......... thats why an edit button would be kewl.......wouldn't it?
drop a fuse on your cig lighter positive side...... it's right there!!!
The reason I asked is because the Cobalt gauges have that indigo sort of look, don't they?  I figured it was possible that they might need the full 12V all the time and have their own sort of dimmer control or something.
If it says 12v dash though, then that usually means the dimmer (also called dash lighting).
The cobalt gauges use blue leds that shine through the dial.
The wire from the dimmer switch you probably need to tap
into is the grey one.
Alright here you are. If you bend down under the dash and look up you'll notice 2 big thick wire looms. In the one closest to the door there is a big thick pink wire. i think it's 8gauge. there are 2, so just test them. This will be your power source it is the acc keyswitch. Now for illumination of the lights, if you pop off the steering wheel column shroud you will see a bunch of wires. you're looking for the white wire (corner lights) this will turn the illumination on only when your corners/markerlights or headlights are turned on. As for the ground I use the plate under the dash the metal one w/ holes in it. Works great for a ground.
If you have a tach nd your tach wire adapter doesn't work (like so many that i hear of) it's possible to wire it up to a 1 pulse signal, even though it's a 2 pulse engine set up. the only thing it will do is be erratic (jumpy from 1k-0k)b/c of the 1 pulse under 1k. But you find your PCM under the hood and locate the wires. there is a white one. Tap into that and you have a signal
 if you have an A/F gauge tap  the purple line (if it's an autometer) into the line after the sensor itself BUT before the stock plugin harness. where it's still a single line. Those are the common gauge questions i see.. So i hope i answered them all for you. If you need help shoot me an IM or an EMail
-Saint Augustine
when i wired my autometer guages, I tapped into the green wire I believe on the back of the dimmer, now my dimmer doesn't work. there is only one spot on the dimmer where both the cluster and gauges light up, if I move it at all, the lights go out, any clue what could cause this?
Wild Weasel wrote:The reason I asked is because the Cobalt gauges have that indigo sort of look, don't they?  I figured it was possible that they might need the full 12V all the time and have their own sort of dimmer control or something.
they do use blue LEDs as mahcmos said. and it's a true blue the pictures don't do them justice at all. I almost didnt buy the ones i have b/c of the pictures. they're bright as hella t night too. lol
-Saint Augustine
Troll:  The problem with your method is that the gauges will always light up with full brighness.  If you use the dimmer wire, they'll have about the same intensity as the rest of the lighting.
cmunn:  No idea man.  Like I said...  I tapped into the wire going into the gauge cluster.  I think it's the grey one as mahcmos said.  Easy enough to test with a voltmeter.  Just find the one that varies when the dimmer is moved.
your best bet would be to go to your dimer switch....... and test one of those.......
you don't want to mess anything up at the cluster... by probing the wrong wire
buzz122 wrote:your best bet would be to go to your dimer switch....... and test one of those.......
Can that even happen?  I just stuck the probe in the end of the connector with the cluster unplugged.
Of course, I'd already read the wiring diagram and had the right wire and was just probing to make sure...
What bad thing can happen from sticking a voltmeter probe on the wrong contact?  It's not like you're putting voltage into it, right?  Or would bad things happen when you ground it?
Im having the same problem, the dimmer switch hook up didn't work for me at all, Ive got an 04 cav. Any one got and Idea what color the wire is going to the dimmer, that you have to wire into to get the damn things to work. I also have the cobalts, they look freakin awsome.
Should be getting my pillar from jason wendsday so i will finally be installing these guages this weekend.  I'll just test the wires on the dimmer switch.  maybe ill do a tut on these just so everyone is clear.
~Riki
Car Domain Site
Okay i tried to wire them to the dimmer switch and none of the wires lit the guage.  and i cannot find the o2 sensor connector on a 04 eco.  I can see the sensor and i trace the wires but no connector.  Its the one right on the drivers side on the header right? (sorry it was 1 am and i could see very well so it might not even be the right sensor. lol)
~Riki
Car Domain Site
I can't help with the Ecotec, but for the dimmer...  hit the wire with a voltmeter before hooking it up to your gauges.  Ensure you're getting voltage and that it varies when you turn the adjuster.  That will be the correct wire.
Note that there will only be power when your headlights are on.  If you want constant power, you're going to need a constant source, live when the car is in run mode.
It won't dim though.
I had them hooked up to the dimmer switch, turned the parking lights on (so that the guage lit up) and turned the dial... nothing.  Did this on all 4 of the wires.  Maybe ill try again later on it was 1 am after all.
~Riki
Car Domain Site
