Just needed to say that.
No matter how i wire the switch the leads are so close together that they short out and blow the push button section on it.  these are really badly made.
~Riki
SPONSORED BY: No one!
Car Domain Site
Have you seen the button?  I cant think of a way to bend them that would make it better
~Riki
Car Domain Site
They do make female connectors with plastic around them to prevent what I believe you may be speaking of.....................
Dunno.
Those are the connectors that I am using.  I emailed Ignited in hopes that they would send me just the black box part so that I solder wires straight to the connector and then heat shrink around them so they dont touch.
~Riki
Car Domain Site
If you're using shielded connectors how they contacting each other then?
Sorry but I do not understand why you're having a problem with this.
i thought you were talking about the ones with just the connector and the plastic bottom.  I'm just using those not the ones with the plastic around the connector.
~Riki
Car Domain Site
If you can't wire that switch without shorting it you need to stop doing your own wiring. That switch has plenty of room.
<A HREF="http://www.cawpin.com">
<IMG HEIGHT=100 SRC="http://www.cawpin.com/images/carpics/thumbs/Jeep_new_04_th.jpg"></A>
  umm okay.  With using connectors it doesn't have enough room. The smallest connectors i could find are still to big.  So  I'm going to solder the connections and use heat shrink to protect them.   As for my wiring skills.  I know I'm not the best at it but that doesn't mean I'm going to stop doing it myself.  I know what i did wrong and I learn from my mistakes.  I was just mad last night and that just added to the fire (need to stop trying to quit drinking).
~Riki
Car Domain Site
looks pretty easy, just get some solder and heat shrink and it should be a snap
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
all the connectors are too wide to be exact.  I dont see a problem with soldering the connection.
~Riki
Car Domain Site
what about the .125 sized females, they would e the same size that goes on one side of a regular speaker.....
but then again, youre gonna solder it on there, which is a better way oof going about that problem..... any particular reason why you didn't want to solder it in the first place?
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
Its just a PITA to solder it on.
~Riki
Car Domain Site
Um... if you ever need to remove the switch you'll need to cut crap.
It just doesn't make sense to me... I have an IGNITED push button starter.  I used female butt connectors and wired it up like that.
Works like a charm.
I really don't know what your issue is...
Good luck.
-Chris-
-Sweetness-
-Turbocharged-
I had an ignited purge button for my Zex kit. It was illuminated and it looked awesome at night, go to a parts store and buy the proper crimp on fittings, it will be worth the effort when your done.
good luck
or while youre there, or RR, find a swicth that you like......
