Does anyone know if the center console (The part where you shifter is) is the same from 2000-20005. Im looking at a 04 LS 4 dr center console just not sure if it will fit the same. Thanks.
I think it slightly changed in 02. I think they only added a cig lighter on the passenger side of the console. Other than that, it will fit without modification
design slightly changed in 02-03 but the mounting points and everything are the same from 00+. just don't try putting a 95-99 in or vice versa. console will sit crooked unless you swap all the mounting brackets too.
SO EVERYTHING!
anyone know if the power window switch panels are the same size on the 4dr as the d4. I know theres more buttons but is the panel itself bigger?
you think its the same size or bigger?
