Ok, I think this is in the correct forum, if not Mods please move it.
I am looking for some kind of a laptop mount to connect to my glove box or I can install in my glove box and let it slide out to set my iBook on.  I have googled this a bit and havent really seen much, so if anyone know please share the info.
Thanks.
make a custom one, or drive a crown vic
Causa latet vis est notissima
 DIY Clear 03+ Headlights
Drive...
.not ride in a crown vic..
big diff...
I recommend checking out one of the laptop mounts from Galls.  The department I work for uses them in our Crown Vics and in our Impalas.  They're not a direct fit but it mounts to the floor and it can be altered to fit I would think.  They're expensive, though.  Like $160 or so if I recall, but I also got a small discount.  But on the bright side you can position the mount so you can use the laptop from the driver's seat.  I mounted one in my Nissan 180 SX to use when I'm tuning the EMS.
im making one right now actually. mine attaches to the seat bolt on the passenger seat. its all custom welded by me. its in primer right now. and waiting for paint. i just have one piece coming up vertical from the floor then a 45 degree radius piece of pipe connected to a piece of pipe that fits around the vertical piece and it has a set screw with a T handle to be able to loosen it so tha passenger can use it as well. and then on top of the radius piece is another flance that will be welded to the laptop plate and will swivel also. i will try to take pics when im all done to better explain it. and i got my ideas from galls actually.
