Ok I know this has been asked a million times already but I searched and I think I found where im supposed to hook up my connections for my volt gauge.  for my glow do I hook it up to the green wire on my havc? also is there a better place for a switched power source that is easier to get to cause I cant get to my ignition cause the plastic panel on the underside of the steering column.
I used my radio for the power source.
Tap the brown wire on the headlamp switch for the gauge to lite up when you turn the lites on.  The brown wire is on a harness that has a total of 6 wires coming out.
The colors are Black, Pink, Dark Blue, Orange, Black, Brown. The harness is located at the top of the stering column, just pull the top half of the cover. The brown is the 12v source that comes on when the switch is put in the park (running) lite position.
