trying 2 figure out how to take it off, cos the vent selector got messed up, went down and checked it out and found the cable was bent, any thoughts how to take that thing off?
knock if you buck
are you trying to disconect the cable from the hvac panel?? If so turn the temp. control knob all the way to hot. It's got a hook that hold's it on there it'll pull right off.
if your trying to remove the hvac controls, take the radio bezel off and then there are screws right there.  remove the screws and you can pull it out
yeah the whole thing so i check whats causing the cable to not move, i have one of those weird climate control (03 cav)that when u cut on ur defrost the AC will also come on, i remove my dash and radio bezel already,and unhooked all the said cables, but still won't come off
knock if you buck
