I have power windows and locks, just want to know if I can transfer all this into a door that had manual everything. Reason I'm asking is my pass door is beyond repair and i wanna swap a complete door from a donor car
Grimor wrote:yes
but it will have the hole for the wind up windows and no hole for the power door lock switch... i dont know if the passenger side has one but if it does it wont have the hole.
simple minds talk about other people.
average minds talk about events.
great minds discuss ideas
I'm assuming he has the door panel from the old door as well..
Causa latet vis est notissima
DIY Clear 03+ Headlights
Let me know if you need help cutting the new hole for your power lock switch assembly. I can template that out for you so all you'll have to do is tape it to the door and dremel it out.
I have done so many templates over the last 2 years that one will only take me 5 minutes...
yah i have the door panels for both actually..but i was referring to just the door itself, as in a strip'd door that had all options vs. a door that had nothing...would both framings be the same.
But I believe i got my answer..thank you
How did that work out for you? I would like to do this myself. any tips?
Well I got as far as taking the panel off my power doors(which are on car), then just compared them to the manual type doors(in garage). I was gonna get into depth with it..but i then i started adjusting my gravana coils for the winter snow to come..since then i just haven't got back onto that project for the doors. But so far it looks like it will all bolt up. Once I get back onto this, i'll post a how-to or something
Ok I took the door panels off,
Mirror - This will be the easiest to replace. Just three nuts.
Lock - Actuator and latch looks like it one part.
Window - The bitch held in by rivets. I don't know how it actually moves the window, and I'm
afraid if i just go and drill them out if something bad might happen.
Looks like this is going to be fun.
I would like to know if anybody knows about swapping the key lock as well.
eh the body shop will know how to do that.
I'll take a better look tomorrow.
