I need to swap a deck for a better one I got used for cheap. I heard this play alot before and the one in my car cant play cds without skipping when I kit a reflector or a little piece of gravel.
I dont know how to get to the radio, and would like to get some know how before I start. I think the front just snaps off, but im not sure and dont want to make a big ooops and break stuff by forcing.
quick responses would help, since I would like to get it done this evening.
thanks.
u have to remove the center air defogger vent. it has a screw holding it on . then the top part of the dash has to be removed. its a pian but its worth it!!!
takes about 5 minutes, and a total of maybe 8 or 9 bolts
RIP Kasey Burleson, and get well soon Chris Shelly
yea you have to take the top of the dash off because the bezel has a bolt right above the 2 center vents and 1 right above the drivers side vent.  when i took mine out, i never put them back in so now mine is just snapped in and its easy to remove
1 bolt on passenger and 1 bolt on driver side (remove plastic panel)
remove 2 bolts up inside glove box on metal strap, holds dash near air bag.
remove torx head screw/bolts that hold dash to glove box
remove phillips head screw in dash vent
remove 2 bolts under dash vent
lift gently, dash unsnaps from remainder
remove top of steering column cover (plastic)
remove bolts from radio bezel where dash cover unsnaps (3 i think)
remove 3 bolts for radio
thats about it
14.82 @ 97 mph
[quote=ßãggéÐÇåv98  (Ûñqùðtäß£è Øñé)]yea you have to take the top of the dash off because the bezel has a bolt right above the 2 center vents and 1 right above the drivers side vent.  when i took mine out, i never put them back in so now mine is just snapped in and its easy to remove
x motha-f'n-2
i had 1 holding it til just recently..then removed it..
thanks you all. I took a nap and ended up sleeping too long, now its to late, but will tear into it soon. ha ha. I woke up and was like DANG i need to get ready for school, thinking its like 6 am. I throw my clothes on, stop and think, then remembered that I'm a goober and its only about 10 p.m.
anyway.
thanks again. will print this post for direction.
