Ok i had best buy put in my cd player..when i got the car back i realized something, the fuel and temp gauges light up fine from 0-49 on the speedo are dimmer than they should be at night...as is 5-7 on the RPM's..ive tried smackin the dash..love tap, everything and nothins worked...how many bulbs are back there and might i have one or 2 blown ones...if so how easy are they to fix, are we talkin takin off the whole dash or just the radio bezel
00 Z24
My Other Ride
RIP Saint...Semper Fi.
sence your working with the cluster you will have to take off the hole thing unless you have skinny hands and arms. im not very familier with the 00's but some people say you cant really do it because of a needle problem.. but corect me if im wrong.
DROCHER wrote:Ok i had best buy put in my cd player
See your main problem is that right there.
After we get past that, i would take it back to them and tell them they installed it wrong.
The only thing i can think of would be that they tapped into the wrong wire for the main power or memory keeper power.
-Seth
sounds like its time for a new cluster
the 00-05 dont have changeable lights like the 99-older do
its prob just a coincinceidence , that they went out out
or they love tapped it a different way
great...@!#$in best buy - ok..now i need to find a new cluster
My Other Ride
wizkiddrummer wrote:DROCHER wrote:Ok i had best buy put in my cd player
-Seth
It still might not be just the bulbs but if it is then yep, new cluster.
-Seth
id say at nught they look about 90% lit up..i dont get it
My Other Ride
Cant you just solder new leds in? Thats been my plan just havent gotten to it yet.
DROCHER wrote:id say at nught they look about 90% lit up..i dont get it
I hope this isn't correct, well actually i do hope its right because i could use a laugh and it'd be an easy fix.  I don't know about your year and if u have one, but if you do, are you sure the dimmer switch just isn't turned all the way up???
-Seth
it is all the way up lol..first thing i checked but thaks
if it was that i would give up driving for ever
ive tried "love taps" and that didnt work either
My Other Ride
on my cluster I believe there are 5 bulbs back there.
they are held in by a green socket that you can twist out.  You can replace them.  You simply twist off the old one and twist on the new one.
On the 2000 cavi the bulbs dont twist off. their soldered in. But like i said if your willing to try it yourself all you have to do is heat up the existing welds to pull the light out then solder in new ones. I ordered some new red leds and im gonna try putting those in.
ima talk to my older brother...he solder's for his work so im sure he could do it
My Other Ride
Have you tried to see if it works with the radio turned off? Or when in the process of taking the gauges out, try disconecting the radio and seeing if it still does it. Like was said above. They most likely tapped into the wrong wire.
they light up the same with the radio off/out
My Other Ride
The radio has no corolation to the dash lights, if it would then you would either have all of the bulbs light up, or none of the bulbs. The problem lies within your cluster. And it's probably just a coincidence...... and theres nothing Best Buy could do, or would do besides short of buying you a new cluster and have the dealeship install it for you. ( most likely they won't )
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
i have an appt. monday for a dealership to look at the cluster
My Other Ride
just make sure when you do the cluster work DONT NOT REMOVE NEEDLES!!! it F's up the hole thing!! and yes you can simple take the back of the cluster off and put new bulbs in.
u can put new bulbs in on the 00 clusters? ive heard many times u cant
My Other Ride
dont listen to them ... i just did two of them today! I'm writing a stick for those how dont know how to do this... but  yes you can. Most people fallow the way in the stick already here and they take the needles off and so on and so forth ... thus f'n the hole thing up. You can change them by take the hole thing out of the car... and takeing the back off of the cluster... there will be 4 -5 bulbs depending on if you have a tach or not. Then you twist those off and ya you will have to see the stick once i finish it... it should be up shortly depending on if i get bugged my rents. so hold tight!
ok now that i found out my friends car was a 99 and not a 00 dont listen to the thread! i will be getting my hands on an actual 00+ cluster and i will figure some way on how to chaneg the bulbs with out removing the needles... so bare with ma while i wait to find a cluster.
rawkfist i need to talk to u..hit me up on aim,yahoo or msn - w/e works for u
My Other Ride
thats why i dont let other people touch my shi* .
they never can do something so easy and still f it up
