dose any one know how to hook these up to a car?i got 4 comeing to me and i wanna hook them up but there computer ones
03_CF_Blues wrote:if they are built for a computer, you should be able to just use the power and ground wire that go into the transformer should be as easy as hooking up power and ground or to a switch
What he said.
You may want to take a look around www.oznium.com, especially the forum (I'm a member on there as well). There's a lot of information about lighting... that's what the site is, a lighting store with a top-notch forum attached.
X2
but if im not mistaked
Oznium must have switched brands of cathodes
cuz when i 1st ordered from them the 12" cathodes seemed fatter and longer too...
::shurgs::
but its very simple..ground...hot...trnsfrmr--cathode...
yeah i know but theres 4 wires 2 black 1 yellow 1 red then also theres a a transformer
blakc and red are ground and power
yellows 5 volt maybe 5.5 volt. shouldnt need it at all. and only one of the blacks is needed. but id ground em bothe anyways
All you need is the black and red wire that plugs into the transformer, and wire those to a switch.  That is how my whole interior is lit up with, as well as wheel wells, and trunk.  I also have some under the hood too.  No need for the extra wires that are included in your kit.  You can also go to
casecooler
well i got my lights in they gave me the wrongh color and one was broke so i emailed them and B$%^hed and they sent me the right set and never asked for the other ones well i was in luck they sent me blue ones so i put 2 in the beater and the beater is blue
 and thank u all for the help they work.
Crystal(CrazyCavGirl) OR Jacob wrote:any pics??
j
i can get them later tonight
Hey what ones are those? the 4" or the 12"?
Yeah.... I know whatcha mean... the 12" neons that I replaced with cathodes were brighter than the 12" cathodes.
LarryMartin830 wrote:Wojo wrote:those are BRIGHT
not really
they look bright.............
j
get a hold of area51 his whole car inside and out are filled with those.
just a little update i just orderd 12x12" cathods and 1x6" cathods
damn it wrongh site its www.case-mod.com
