ok now i have a lil project in mind and i want to fill that cigarette lighter whole and i have no clue how to do it...i need a material list and the steps on how to... if any one is intrseted on helping me.. if not ill fig it out some how... thanx to any one who helps
ps.. i have no clue how to fiber glass so no one tell me to do that lol
i also apologize for being a retard and askin about this... its probly really easy but i have no clue
you have 2 options, 1 being fiberglass(which is really easy, FYI) or 2 drill it out, and put a button or switch there.
Or 3, a couple people put a guage there... I saw pics of it in the Photos forum, can't remember what the thread title was though.
Here's a
Fiberglassing Tutorial for ya
hmm................This gives me a sweet idea.....If i rip out the cig lighter, you think you can put a "START" button in there? How do you do a start button anyways....
Same way as remote starters work (not the keyfob remote, but ones where you jump the battery to the starter and hit a button... more so when you are working under the hood)
Run a
fused hot from the battery, to a momentary push button switch able to withstand the starter amperage, to the starter.
Or, use a relay. I'll draw up something this evening and post it up when the forum comes back online.
Nice,
I have no idea what you said lol so youll have to show a diagram like you said and explain some of these technical terms.
well can ne one tell me how to fiber glass it so its smooth and all that cuz i just dont want it there i want it empty.... if not... ill just leave it... can ne post pics of wat they did with that spot?
Hummm, switch would be sweet.
98 j-body sedan
Dufus Head wrote:Nice,
Here's some instructions (with pics)... not for a Cavi/Sunfire, but the concept is the same. Pics are interior shots of a Miata, but since they have the lighter in about the same spot as Cavi's, it's a good approximation.
Starter Button Instructions
Anyone that is familiar w/ the wiring harnesses care to ID the correct wires to use when installing?
I used this hole for my nitrous activation switch. Cut out a stainless steel "circle" slightly bigger than the opening, polished it to chrome and drilled a hole for the switch in the center. Put the plate behind the opening and once the switch is tightened down, it's in the securely and doesn't move.
