I was just curious, how well has it workd when paintin ur doors? ive been told no to do the handles cuz the paint comes off easy, and second to use a 4 or 500 grit sand paper and sand all the parts. (wet sand)  I just want to know if any of you have done ur doors and how well did it turn out?
you should totally searchhhhh
JBO'S Mr. 64.....
There is a huge step-by-step guide just posted like 4 days ago, huge thread now, you can't miss it.
if you dont want to sand then go to the store and get the paint can called "fusion". spray it on there and let it set for a few then your done.
Yea, The step-by-step guide is great. Thats what I used as a go-by. But, to answer your question about the door handles, I did NOT do mine because I just thought out of common sense that it would get rubbed off or cracked. Other than that mine came out great
2005 Cavalier LS
"Sow your oats on Friday night, Saturday pray for crop failure"
I painted my door handles and they have been fine for almost two years now..Do it right and they will be fine..oh and mine are white too thats the worst color to keep clean but they still look new.
I think you should be fine to paint the door handles.  Like CzapskiKandyKav said tho, make sure you do them right.  I you prep them good, and apply many layers of clear, you should be all set.  As far as sanding them, if your just changing the color, yea just scuff em up quick with like 4 or 500 sandpaper, clean the door, then paint.  If you want them glossy, follow my
How To Repaint Your  Interior thread.  Good luck.
Wide Body Progress
SliMMaTiC (Tom Sylvester) wrote:sndsgood wrote:i dont believe you can paint interior pieces
its a joke look at his sig
