i was looking around ebay and saw some for sell but they have fewer miles on them than mine......My Question is how can I adjust the mileage on a cluster i buy off Ebay?
BTW: My fuel and temp gauge dont work...
If I'm not mistaken, I believe the mileage in the digital clusters is actually stored in the computer, and not in the cluster itself. When you plug in the replacement, the mileage should set itself properly.
problem though mine is not digital.....
you gotta take the back off, then there are 6 screw where the mileage indicator is located at. I think the tool is like a T-25. You gotta take those out and the thing wll pop out. Now take the one you want to put in there and just screw it back in. It's simple just be careful.
so would this work with a digital cluster also?
just remove that mileage piece and screw the one you want to keep back in?
the reason i ask is cause my vehicle is a 99 and its digital but the 98-99 digitals were stored on the bcm inside the cluster.....
JBO'S Mr. 64.....
nope, this only works if it is mechanical. Digital you can't do nothing about, your stuck with it.
I think the law says that when you change it, you have to put an indicator somewhere on the car of the date it was changed and the readings on the old and new odometers when it was changed.
Then you're all set.
Mr.64 (Shaune Drake) wrote:so would this work with a digital cluster also?
No, won't work on a 98-99 digital cluster. There is no BCM in your car, but yes, it is stored in the cluster.
i have digital too. so if i swap it out, i'll just have to note what is was when i do it? can't swap a digital with a mechanical?
to change the tumbler on a cluster is easy. no special tools needed. i swapped mine out when i got a new cluster. you just take the back off the cluster and theres a few screws holding it in place thats all
