Ok before I start I will state I have searched and the best I could find was this:
Installing Gauge Overlay/Tapping Dimmer Switch
I understand that everybody mentions this silver wire.  Now I own a 2005 Cavalier and I looked at the dimmer panel.  there are 4 wires coming out of it and none of them are silver.  Am I looking in the right place?  They also talked about tapping into the turn signal, but is this really necissary?
I think things like this should have it's own How To section that can only be inserted by moderators.  But hey what ever.  Any help would be useful to find out the solution to this.
my dimmer wire in my 03 cav is brown. i think thats what you're looking for
Or you could hook it up to ur HVAC, the wires will be yellow and gray. It will also work with the dimmer switch then.
LOL something useful like that so the noobs won't be asking the questions over and over. You're crazy. Never gonna happen.
now can i hook up my digital gauges up on my dimmer switch?
Opening Soon Kustom J's
95Vet wrote:Quote:
lol you do realise you just called him a noob right?
2006 Black Cobalt SS Supercharged G85
13.91@102.77
I'm positive I used a gray wire.  Use a voltmeter and find one that varies when you turn the dimmer switch.
i think i used a brown wire in my 00 when i did gauges in that
It was a silver wire in my 97 and 99 Sunfires.  It may be a different color in newer ones.  Like Wild Weasel said you can use a voltmeter to find the wire.
Well I guess with different years they changed the colors.  But the one for my 05 ended up being brown with a white stripe.  I should have used a volt meter from the beginning but all of my tools are sitting behind a boat motor which I was not strong enough to lift up and move myself.  Damn crates.
Thanks for your help guys.
And Jose(95Vette) I'll let that one slide for now
