HVAC cable - Interior Forum
HVAC cable
Wednesday, March 29, 2006 2:48 PM
where does the hvac cable run to on the 03+, mine slipped off the back but when i put it back on i still cant control anything.
http://www.cardomain.com/ride/2250810
Re: HVAC cable
Thursday, June 15, 2006 10:20 AM
runs up to a mode door. You need to take the top of the dash off. There is a bulletin at the GM dealer to replace the foam on the upper door because it gets stuck at the hinge point and you have to use force to move the knob. Or, you can cut the foam back. You may need a new cable too because it may have gotten kinked.
Here, straight from GM-
Subject: Difficult to Change HVAC Mode or Air Blows Through Upper Vents Only (Replace Foam on HVAC Mode Valve) #03-01-38-005D - (01/12/2006)
Models: 2003-2005 Chevrolet Cavalier
2003-2005 Pontiac Sunfire
This bulletin is being revised to add the 2005 model year. Please discard Corporate Bulletin Number 03-01-38-005C (Section 01 -- HVAC).
Condition
Some customers may comment of difficulty in changing the HVAC (heating, ventilation and air conditioning) mode or that air blows through the upper vents only.
Cause
This condition may be caused by the foam on the HVAC mode valve (mode door) coming loose.
Correction
Do This
Don't Do This
Replace foam on mode valve.
Do not replace the HVAC control head unless damaged.
Technicians are to replace the foam on the HVAC mode valve (mode door) using the following procedure:
For Chevrolet Vehicles
Remove both instrument panel outer trim covers. Refer to the Instrument Panel (I/P) Outer Trim Cover Replacement Chevrolet procedure in SI (Document ID #874755).
Remove the instrument panel trim pad. Refer to the Trim Pad Replacement-Instrument Panel (I/P) Chevrolet procedure in SI (Document ID #831881).
Remove the instrument panel accessory trim plate. Refer to the Trim Plate Replacement-Instrument Panel (I/P) Accessory Chevrolet procedure in SI (Document ID #831885).
Remove the air distributor duct. Refer to the Air Distributor Duct Replacement Chevrolet procedure in SI (Document ID #646956).
Install a new piece of foam on the mode door valve, P/N 89018656. Refer to the instruction sheet that is included with the new part for detailed foam installation instructions and part illustrations.
Install the air distributor duct. Refer to the Air Distributor Duct Replacement Chevrolet procedure in SI (Document ID #646956).
Install the instrument panel accessory trim plate. Refer to the Trim Plate Replacement-Instrument Panel (I/P) Accessory Chevrolet procedure in SI (Document ID #831885).
Install the instrument panel trim pad. Refer to the Trim Pad Replacement-Instrument Panel (I/P) Chevrolet procedure in SI (Document ID #831881).
Install both instrument panel outer trim covers. Refer to the Instrument Panel (I/P) Outer Trim Cover Replacement Chevrolet procedure in SI (Document ID #874755).
Verify proper operation of the HVAC system.
For Pontiac Vehicles
Remove both instrument panel outer trim covers. Refer to the Instrument Panel (I/P) Outer Trim Cover Replacement Pontiac procedure in SI (Document ID #889992).
Remove the instrument panel upper trim pad. Refer to the Trim Pad Replacement-Instrument Panel (I/P) Upper Pontiac procedure in SI (Document ID #875317).
Remove the instrument panel accessory trim plate. Refer to the Trim Plate Replacement-Instrument Panel (I/P) Accessory Pontiac procedure in SI (Document ID #874606).
Remove the instrument panel trim pad. Refer to the Trim Pad Replacement-Instrument Panel (I/P) Pontiac in SI (Document ID #831884).
Remove the air distributor duct. Refer to the Air Distributor Duct Replacement Pontiac procedure in SI (Document ID #646957).
Install the air distributor duct. Refer to the Air Distributor Duct Replacement Pontiac procedure in SI (Document ID #646957).
Install the instrument panel trim pad. Refer to the Trim Pad Replacement-Instrument Panel (I/P) Pontiac in SI (Document ID #831884).
Install the instrument panel accessory trim plate. Refer to the Trim Plate Replacement-Instrument Panel (I/P) Accessory Pontiac procedure in SI (Document ID #874606).
Install the instrument panel upper trim pad. Refer to the Trim Pad Replacement-Instrument Panel (I/P) Upper Pontiac procedure in SI (Document ID #875317).
Install both instrument panel outer trim covers. Refer to the Instrument Panel (I/P) Outer Trim Cover Replacement Pontiac procedure in SI (Document ID #889992).
Re: HVAC cable
Friday, July 28, 2006 4:15 PM
thanx
Kill list:03 eclipse, 06 GTO, 04 Mach 1 Mustang
