i dont know if you guys have seen it or not but autozone is selling this "sound deadener in a can" type of stuff..now,i know this cant possibly be as good as things like dynomat or the like, ...but..does it work at all?? i ask because im sanding down my interior pieces right now and i dont want the added weight or dynomat so i thought that this spray stuff might give me alittle bit quieter cabin but without the extra weight....any thoughts?
ive heard if any use this it's in the corners or other hard to reach/cover pieces. besides that would be alot of cans to by to do the car with. the deadner mats work best.
im not wanting to do the whole car...im just wanting to do the back side of the plastic panels ive pulled off and sanded...i havnt pulled up any of the stock insulation so far...just wondering if anyone has used it or if you think itll even do ANYTHING..??
i use this stuff on the inside of all my sub enclosures. works great. takes a while to cure, but turns like a rubbery coating.
im also adding it to the backside of all my panels, and certain sections of the underbody
i used it in the back of my CRX, when i had it, but the stuff never fully cured, and it was stilll sticky in spots, especially when the sun got to it.......... i eneded up recovering everything with the mat
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
i dont think youlle get the noticable diffrence that your wanting, to get that your going to need to add allot giving u the same weight mat would. i use the spray in areas that the mat is just to hard to get to. one thing i'd suggest is trying undercoating on all your wheel wells. about a can per wheel well. this will help absorb some of that road noise.
well ..none of the noise really bothers me..my cars loud.ill admitt it...i just wanted to put something on the panels while they were out ya know..maybe something that would help alittle..
you can buy it by the gal. at partsexpress.com
Opening Soon Kustom J's
what kind of liquid deadender do you use sndsgood... is it the rubber undercoating stuff? did you spray it inside the car?
JBO'S Mr. 64.....
yo sndsgood,
how did you apply the spray stuff to the inside? a gun or something?
JBO'S Mr. 64.....
i have just used rubberized undercoating for all the eareas i couldnt get to.very cheap..dries good and doesnt smell...also if you have a water problem it coats the panels well..i sprayed it where the back set is..on the inside of the quarters thorugh those holes..phil'
