What is the best location to tap ACC for window motors? I have installed a remote starter so the wires at the key switch are pretty packed in there...
Behind the Radio its easier to find
WIper fuse is switched 12v
at the fuse box under the hood, or the harness under the steering column
You should have tapped into the keyed wires under the steering column also, so they would not be so packed together......
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
They are not that packed together. They are properly soldered and heat shrunk and then electrical tapped for extra meassure. If I were to add wires to this bundle, then it would be packed. in addition i don't want to undo these carfully made connections.
Soldering under the steering column is quite difficult and i wanted a good juncture.
my guess is Toronto...
"Silver 2001 Cavalier z24 5 speed 2 door sunroof and power everything "
AEM Short Ram Intake
B&M Short Throw Shifter
i would go, for under the hood, in the fuse box then.
Glad to see that you soldered the stuff together, instead of just T-tapping like most ppeople do  !!!!
Ha ha ........ Toronto !!!!
