Alright got my LEDs installed and they look awesome, only problem is the LED on the right keeps flickering on and off, any suggestions?  I've torn it apart twice and everything seems ok, is there anything I should be lookin for that could be causin the problem?
Did you check to make sure it's in all the way? If it is I have no idea...
____________________________________________________
2002 2.2L -Base Model- (not for long) Black Cavalier
Make sure it's in all the way. If it is, try bending the wire contacts on the bulb itself out a little to make sure it's making a good connection. If it still messes up, see if the bulb part is loose in the socket, not sure if that'd be fixable or not, I know I broke one bulb like that.
you know, theres a whole big thread regarding this..........
wait for it... wait for it... NOW GO!!  ---> '02 LS Sport <---
Yahoo IM : buzz122          AIM : buzz122cav
yeah, but I didnt wanna interupt that thread with my problem.
Well, wondering if the Sunfire HVAC is the same as the Cavy . . .
If it is, try to make sure then the whole bulb fitment (plastic piece and all) is touching the conductors.  If you look on the plastic piece that the bulb fits into, you'll notice that on the wing-looking ends, there are the metal pieces that have to touch the back of the HVAC panel.  If you can, try to bend them down more so that they'll touch and hold firmer onto that connection, and you shouldn't have an issue.
well, thats what the thread was intednded for. for any and all HVAC lighting questions.......
NEwayz...... is it just one bulb, or is it both ?
DOOOOHHH !!!!
umm, i should really pay attention more.........
if i'm not mistaken, the one on the right is the first of the two in the circuit, so do what Exodus 259 stated, and check your connections inside the socket, and on the replacement bulb
if he got them off ebay i have the same problem. and its the bulb itself. ive switched them around and teh same one still does the same thing. i just got used to it tho. till i can buy a new set.
