ok im trying to take off my back panels where the plastic is but i cant get off the freakin nut that holds on the belt!! how do you get that off???
the one thats holding the part that the seat belt goes through
front passangers sorry didnt understand what you were asking
Its a star bit, someone else can tell you the number but i know its the star bit.
yeah i used one but i broke it off in it because it is so tight.  you turn it to the left right?  what if i cant get it off??
Its a Torx T55 or T50 and its probably held in with some type of threadlock. Get an impact type bit (make damn sure it fits tight otherwise you'll round it out), a long socket (preferrably 1/2"), and a breaker bar. Apply steady pressure to it, it should come out. If that doesn't help, spray some PB Blaster on it and let it soak for 5-10 minutes and try again.
yah they are tight little bastards
i was cranking on mine and when it finally came lose i ended up ripping my hand really good on a metal bit
so be careful
lol yeah i just nailed my hand but i did get it off!! it was the t50, thanks alot guys for your help.
Hmm, when i took my pass seat belt off at the bottom to remove that panel, it wasnt hard to remove that bolt at all, just used the right torx bit with a 3/8 ratchet.
