How can I get the fabric inserts on the doors out and back in the same way they were?  It would be easy if they were pop outs or screwed in.  But the pegs in the back of the door are melted to the plastic.  So how can I get them out and put them back in the way they were?  Also is there a way to seperate the door at the seems through the middle of the door?
2004 Ecotec Cavalier 9.9 in the 1/8th mile.   15.7 in the 1/4 mile.
Can somebody help me out.
ok i did mine by cutting the plastic welds off with a utility knife from the top and just taking the top of the plasic that holds it on. then when you have the fabric torn off you have to sand the cushion left over crap off. I did my door panels in vynil so thats the path i took. and i used glue to attach the vynil to the bare panel. when it was time to put it back in i bought really small screws about half an inch long and put them from the back of the panel to the door.  BE VERY PATIENT IF THIS IS ATTEMPTED BECAUSE IF YOU ARENT THEN YOU WILL BE VERY UNHAPPY WITH THE OUTCOME.
THIS TOOK ME A GOOD 2 WEEKS OF OFF AND ON WORKING ON IT.
http://www.j-body.org/frame.php?url=http://www.cardomain.com/ride/2155867/1
there might be a pic or two of my door panels in here.
think about it hard before you consider trying it
hope i helped out a bit
lata
i just looked at my domain page and there isnt any pics of my door panels
give me a lil bit of time and i snap a few later tonight and put them on the page
lata
kurt johnson wrote:ok i did mine by cutting the plastic welds off with a utility knife from the top and just taking the top of the plasic that holds it on. then when you have the fabric torn off you have to sand the cushion left over crap off. I did my door panels in vynil so thats the path i took. and i used glue to attach the vynil to the bare panel. when it was time to put it back in i bought really small screws about half an inch long and put them from the back of the panel to the door.  BE VERY PATIENT IF THIS IS ATTEMPTED BECAUSE IF YOU ARENT THEN YOU WILL BE VERY UNHAPPY WITH THE OUTCOME.
lata
hey kurt did you vinyl over top of the fabric or did you strip it?   dunno how vinyl on fabric would work out.  i did something to this effect in my 2nd gen eclipse but i glued fabric over top of the old. and as for the melted pegs i just cut them like said above and used hot glue(which didnt hold up as i expected but superglue was a little better,  tiny screws and glue together should keep everything intact
2003 2.2L ECOtec Cavalier
*Mods*  (im poor)
Butchered hole in filter box
Turn down no name dual-tip exhaust
i stripped the fabric and then sanded the panel smooth from all the glue that was holding the fabric on
I have a 1995 cavy and I want to recover the insert near the door handle.  I did not see any plastic tabs or anyhting of that sort.  It looks like it is just a off part that the carpet goes on.
