Ok folks, i did a search and did not come up with anything definitve, that answers my question one way or the other.
Does the dash pad on the 2003+ sunfires swap perfectly to say my 2000 fire?  Do the vents line up, and is there anything else i need to be aware of?
Yep, like said above its a perfect fit.  Only difference is the air ducts, but they will still work fine.  I have had an 03 dash in mine for over a year.  If you plan on buying one somewhere, try to find one in a junkyard that has the airbag cover blown.  Sometimes that will be the only thing wrong with the dash and you can get the whole dash pad cheap (the airbag cover from any year sunfire dash will swap onto the 03 dashpad.).
Sweet, thanks for the replies.
Update:  Not a single junkyard has the dash pad available, how much is it from the dealership?
Im not 100% sure on this part #.  You should check with your local dealership to make sure this # is correct but:
GM Part #22682873
GM LIST: $527.88
GMPARTSDIRECT: $312.93
