Ok stupid me I went and messed with the switch for the power windows that are mounted in the center console.. Its a 97 z24... I broke the switch and now my from right window is all the way down and its supposed to rain tonight... Is there anyway at all I can get that window up either by bypassing the swich or taking the door panel off.,..... PLEASE SOMEONE HELP!!!
you'd have to feed 12v to the proper side of the motor, and ground to the other to make it go up. The windows work on reverse polarity. Power going in one side of the motor makes it go up, power going in the other side makes it go down. If you put power to one wire, ground to the other, and it doesn't move, swap wires and it should go up. Hope that helps.
