I just got my white face gauges.  The instructions seem kind of vague.  It says to remove the black face, and the needles using the supplied divot tool.  Is it necessary to do this, and is there a detailed how to for this mod on here?  Any help is greatly appreciated.
Gotta keep on livin', L-I-V-I-N
For white face gauges on 2K??  Your just supposed to move all the needles so their pointing straight up, and slide the white face gauges over.  Your not supposed to take off the needles at all cause it can ruin the cluster.
Sweet.  Thanks.  How hard is it to remove the stock face, and is it necessary?
no
when i did mine i just slid the white face on over everything
point the needles so they are pointing up
next, you gently slide each needle through their designated holes on the face
next, you slide the face downward gently till the face falls in the factory position
i hope that helps some
All I needed to know.  Thanks a million.
