Ask sndsgood
I'm pretty sure he has those
-Seth
do u have they mounted to the back seat?
Its an inertia reel just like what you have with your stock belts, while daily driving it'll lock up under hard braking, etc.. but other than that is easily lived with just like a seat belt. When you go to the track you turn a nob to lock it in place and its like your standard 4 point harness.
Your gonna have to drill if you want it mounted properly, the child anchor points are another candidate. You should also check out schrothe they have one thats activated by an electronic switch you can mount, and are also DOT approved so you wont get a ticket for using them exclusively either.
-Chris
IamRascal wrote:Your gonna have to drill if you want it mounted properly, .
how would you go about putting something back there in order to connect it?
antbody have any suggestions????
Unfortunately there really is no good place to connect one in our cars unless you put in a bar. rdfabs makes one but then you might as well get a regular harness.
-Chris
yeah thats what i was thinking, ill probably end up getting the rd bar. thanks tho iamrascal
