I got some racing seats and a 5 point harness. Im running my upper harness to the bolts for the child seats in the rear but now i can have a back seat. Im no that worried bout having a back seat but i want to know if there is anywere else i can mount them at
13.1 @ 115
OK... this may not be the right way but, I just bolt my belts down with the seat bolts....can you say- bootleg- I knew you chould.
wj4show@yahoo.com
Auto wrote:OK... this may not be the right way but, I just bolt my belts down with the seat bolts....can you say- bootleg- I knew you chould.
easiest way to kill yourself in a bad crash
heres my seat and were can i get a harness bar at cause i cant find one someone help me out
13.1 @ 115
rdfabs has a nice harness bar
nice seats where did you find those at? comfy? lol
Joey Baggs (Eazy716) wrote:Auto wrote:OK... this may not be the right way but, I just bolt my belts down with the seat bolts....can you say- bootleg- I knew you chould.
yeah, especially since that would crush your spine into a nice fine powder
I have mine attached to a 4 point cage by autopower, RKSport used to sell it... no clue if they still do or not
An idea I've been pondering...
If you are running the harness bar, the belts go over the bar to the rear seatbelt bolt to obtain the ideal angle.
What if you ran the harness over the bar to the front seat lower bolts, would that not also acheive the ideal angle, or is that still a bad idea...
i beleive you want the straps to be mounted higher then your shoulders. then the force of the accident wouldn't cause your spine to compress. if they are below your shoulders it will pull you down in an accident.
Ok, here's what I meant... the red line would be indicative of the multipoint harness, whereas the green line would be indicative of the stock seatbelt... note that both (even using the rear seatbelt bolt) all are anchored below the shoulder line.
not sure how much lower from the bolts the RDfabs bar sits, though
Reason I'm asking is I'm planning a rear seat delete that will no longer allow me to use the rear bolts for mounting harnesses.
why not just mount them to the harness bar
they aren't bar mount harnesses
