I've read it before, and now I can't find it in the search. But what are the specifications to look for when finding a new shift knob for a B&M Short shifter. I just want to make sure when I buy a knob that it will fit properly (I don't like the polished one it comes with).
I was going to buy a B&M knob but it's been discontinued. Jason at A+ was very helpful but sadly the b&m knob was unable to be found.
Words that you can't use in modding: Finished, Perfect, Cheap.
I could go for that one, Jason. I'd paypal you again if we could locate that one.
Sent you one back
How much would that run? I would be interested as well if it was reasonable and allowed reverse lockout.
for the 99 cav, will the 03-05 man knob work on the b & m short throw for the 95-99 man???
help jason plz
http://www.myspace.com/fpsunfire
5 seconds to find another street...
John Higgins wrote:Mark wrote:How much would that run? I would be interested as well if it was reasonable and allowed reverse lockout.
Yeah how much??
How much Jason? I'm interested as well....
Custom Made 04 CF HID Projectors
fpz24 (Akira) wrote:for the 99 cav, will the 03-05 man knob work on the b & m short throw for the 95-99 man???
help jason plz
My understanding is that the 03+ is a threaded knob, whereas the 95-99 has the clip style.
your options are to either a) make a sleeve that will go over the 95-99 shaft to allow something to screw on, or remove shifter, take to welding shop, have them cut some of the shifter shaft off and weld on the end of a bolt to allow for a screw on knob to be used. Only other option is to use something with set-screws. I researched an adapter and the only one I could find was one from Lokar, but the inside diameter is too small.
Example of sleeve on 95-99 (the brass part):
The knob is quality. B&M makes good stuff.
