I would like to know if the interior of a 95 cavalier is the same as a 98 cavalier?? Like exactly the same.
Thanks
yep pretty much, few changes ever happened between 95-99 other than color combinations.
my car has a complete 95 dash, 99 console, 97 front seats, 95 rear seat, 99 door panels, 05 dash pad. i have the 95 rear 1/4 window panels, 95 rear deck panel w/ 3rd brake light and all the trim panels to finish it off, hopefully it will all get installed this winter.
as for EXACTLY the same, cant say, if their both graghite then you should be able to swap both and have an exact same interior, but if one or the other is tan or half tan/graghite then it wont be 'exact'
its when you get up into 00-02 and 03-05 is when pieces become different here and there, but all the same, most  if not all of it can be swapped through any year.
yea it seems like the only thing i noticed changed from 95-99 was the power door lock switch, and the seat patterns, and those didnt even change much
-98VERT- wrote:yea it seems like the only thing i noticed changed from 95-99 was the power door lock switch, and the seat patterns, and those didnt even change much
yeah didnt the 95's have the squary switch? possibly 96's as well? i know my 98 has the rounded ones.
yea those things were god awful ugly too lol first time i seen them i was like wait wtf is that about? glad they got smart and rounded them off.
Hey what about an 03 cavi?..Its hard to find 02+ cavi's in the junk yard to get interior peices...will any other years works? im talking all of it..door panels pillers front side and back panels consoles dashes etc...i havent found any stickys or posts reguarding this
Elmer the wricer hunter..."Shhh be vewy vewy quiet...I'm huntin wrice"
Kill da wriiiicer...Kill da Wricerrrrr..kill daaa wriccceeerr!!!
pretty much all of it should work except the dash bezel (the part around the gauges,hvac and radio)
ok heres an update on my issue...i went to the junk yard and got ALL the interior plastics and door panels off an 2002 cavi 2door...keep in mind I have a 2003 2-door cavi...yes the gage pod doesnt work..all the rest of the dash does..front pillers do after taking some of the black foam out of corner of the roof liner. door panels fit..plasics on floor fit...back dash fits...rear main plasitic section DOES NOT FIT..come to find out the 2003 small rear window is alittle smaller and so plasitic peice shows about an inch all the way around..so it wasnt used...oh yeah I managed to get a factory wing off it..same color was only $30 so what the hell...all the bold holes after drilling were made for it..the lower under metel of trunck already had factory spots to get to the bolts and already had plug there for the 3rd tail light...
the back window's are not smaller...   there's just a difference in the plastic pieces thats all.
