i was removing my driver side door panel on my 2003 LS coupe, and as i started to pull the panel off, i head a peice of metal fall down in the door panel. when i pulled from the bottom the little peice fell out, and i don't want to re-attach the panel without putting the metal peice back on. it's a small brass colored peice, it almost looks like a clip. Any ideas on what it is????
It could be the omega clip that holds on the window crank
Or the clip at the very top of the panel. im not sure what it does but im sure it would help out my door panel vibrating
if it is a u looking clip with 2 sharp prongs in the inside of one side, it goes onto the top sill by the window that hooks onto the panel.. look on the back side if the panel.. you should see some scratches on that or the door on where it came off.
http://www.jbodytuner.com
^^ The real jbody store and forums!!!!!
derric dumont wrote:if it is a u looking clip with 2 sharp prongs in the inside of one side, it goes onto the top sill by the window that hooks onto the panel.. look on the back side if the panel.. you should see some scratches on that or the door on where it came off.
x3
The one on my passengers side fell off.
Caveman wrote:derric dumont wrote:if it is a u looking clip with 2 sharp prongs in the inside of one side, it goes onto the top sill by the window that hooks onto the panel.. look on the back side if the panel.. you should see some scratches on that or the door on where it came off.
x3
x4
i dont have any left on mine
yea.. thanks i figured it out.. i just thought i would take off my passenger side panel and see if i could find the peice on that side
