I have a 2.2 ohv 95 no a/c cavalier. I was wondering if this is a easy job to fix
get on your back under your passenger side and remove the bolts and disconnect the harness and swap em out. Its fairly easy, your just in an awkward position.
It's directly accessible on the passenger side under the glovebox. It's only held on by three screws and a wiring harness. Pulling mine out to remove some leaves and putting it back in was a 10-minute affair.
2000 Cavalier Coupe, 138k miles, 2.2 Auto, Silver (alive)
1999 Cavalier Sedan, 237k miles, 2.2 Auto, White (dead)
not to thread jack, but i have an 03 cav and on the lowest blower setting after off, the blower motor seems to tick, but if i turn it up to 2,3 or 4 it stops, it only does it on that one setting, any ideas???? btw, heat or A/C doesnt matter, doesnt matter what vents either.
many changes in the making
my favorite part about doing bodywork,.......... bondo bugers
There's a leaf or some other piece of crap in it. Remove the blower motor, clean it out, and put it back in there. Had to do it to mine recently.
I don't want to steel anybody's tread either but my blower motor only worked on high any ideas? If its the blower motor its self i have to replace it anyways it just went out on my way down to my moms house and its Freakin Cold with out it!!! Please any help would be nice
read the sticky in the maintance forum
justin stockdall wrote:I don't want to steel anybody's tread either but my blower motor only worked on high any ideas? If its the blower motor its self i have to replace it anyways it just went out on my way down to my moms house and its Freakin Cold with out it!!! Please any help would be nice
you need to replace the blower motor resistor.
i just replaced mine thats exactly what you need to replace my works awesome now altho it smells like burning electronics or burning plastic every so often now i think its that black coating on it burning off coz it was really bad the first time i let the heat run on high for a while now it comes and goes and not as strong
