They send 4 of these ^ ^
They sent with the wheels in the box...but when I put the first two on...the
caps popped off.
oops
These came on the wheels lol
that happened on my buddies blazer, had to grind down the axle shaft to get it to fit right.
www.chevyridez.com
Indigo Blue Dreamz wrote:that happened on my buddies blazer, had to grind down the axle shaft to get it to fit right.
^ Son of a gun!! Just sticks out like a sore thumb..But I am about to go outside and bring a hand saw to it
Rusty brakes are teh gay.
The Silver J......Ridin' Clean....
ConceptR.com
Silvrdreamld904 wrote:Rusty brakes are teh gay.
I assure you they will go away when I begin to drive it!!
BLING BLING!!
Look good...
your front brakes look tiiiny! I tihnk you need a brake upgrade now
caps popped off.
Those are your hubcentric rings. They go behind the rim around the hub. Just incert them into your rim and put your rim on. It keeps it from moving and sheering your lugs off the car causing your rim to go flying off.
Put them on...now when I begin to brake..it makes this loud azz noise coming from
around the front wheel aread..both sides-
THOSE ARE HOT RIMS!!
________________________________________
Daytona Blue, Cavalier Coupe, 2.2L I4OHV
----CLICK HERE FOR A FREE IPOD! EMAIL ME IF U HAVE QUESTIONS!----
That space inside the rim to the hub is what that cures. The noise is most likely something else. But just to be safe make sure that the rims are on right. All the lugs are tight. The back of the rim is actually flat to the rotor. Just check to make sure that everything is good. Maybe you just need new pads. These rims weigh more than your old ones right?
What type of noise does it make?
Man those already look a 100x better than the white wheels!
J-body of Kentucky
Too much bling for me.... but if you like them thats all that matters
HEY YOU!..
YOUR RIMS ARE ALREADY DIRTY!!
CLEAN THEM U JERK!! LOL
those plastic hubs are subpose to go between the rim and the wheel plate .
then your caps should work regular.NOW GO CLEAN YOUR RIMS YOU JERK.
GOT ECOTEC?
Your front tires are on backwards, switch sides.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Those are gonna be hot during the daytime!
Get the noise fixed, then clean em!!!
-Nate (ZeeTwankyFo)
I put the plastic hub thing on...but maybe I put it on wrong...because my steering
wheel shakes ...its noticeable...someone tell me how they are supposed to be on
They are to go on the inside of the wheel where the hole is in the middle. Insert that filler piece so it fits flush with the inside.
very very nice!
good luck with the problem
