Ok, so maybe this is more "scenic" for the performacne oriented.
A closer look at the background:
I had to "clean" out the garage to get the sunbird in there to drop the new motor and trans in. These are SOME of the turbos I have laying around. How many can you count? There is another bottle of spray bellow the black one too, a 10lb NOS bottle... and a 20lb NX is sitting in front of that tool box on the floor.
A closer look at the HKS ball bearing turbo going on the sunbird:
It started life as a Nissan turbo and was sent out to HKS for a rebuild with HKS ceramic bearings, a ceramic turbine shaft/wheel, an HKS compressor wheel/balancing and a full upgraded high-travel/high-boost HKS wastegate system.
There are two of these turbos in that pile. They are the two up top behind the Turbonetics T-61 with the compressor housing pulled off. Only one of them went to HKS, the otehr is still factory Nissan trim.
I just thought you all my enjoy some "scenic" pictures in my garage!
PS: There are ten total turbos in that pile and four more still sitting around in other places. And yes, i do realize how rediculous that is.
Cardomain|
Myspace
forgot to add that the two nissan/hks turbos are ball bearing. A lot of you have already seen my instructions on-line for rebuilding a standard T3 center section. I will be adding detailed instructions for rebuilding a ball bearing turbo soon, as well as a T4 center section shortly after.
Cardomain|
Myspace
u are nuts buddy............sell sum of them.......make sum money.........ill be needing u in the spring
you scratch my ride IMA EAT YO CHILDREN
can i have one? you should share the wealth
i want one too! please!!! i'll be your friend. . . .
(no gay stuff tho)
" ..TQ is SPEED, HP is BRAGGING RIGHTS.. "
^^^^^^^Indeed they are super sexy. This one is a convertible. Man do I love to drive it. let me tell you though... this thing is the biggest pain in the ass that I have ever worked on. There is sooooooo little room to work around in. Not only that, it's is 15 years old and the old engine leaked like crazy. Every bolt is stuck. Right now it is in for the swap over to the built engine and the 5spd swap. Everything under the hood is almost out already.
Ahhhhh... headaches.
I can't wait until this things motor is finished and the new 3rd gen shell comes in to get the drag motor dropped in.... they are sooo much easier to work on.
Here are some more pictures of the bird and stuff for it:
The ball bearing HKS turbo
Port and polished head
Built engine finally coming together
10lb trak lites with G-forca T/A drag radials
AIC set-up to hit 20psi (was originally for the drag car) and the turbo timer
Bottom end back from the machine shop
How she has spent 99% of the time I have owned her
I swear I do not have one single picture of the car running and being enjoyable. Two days after I got the actual car the head cracked and I lost all my coolant. The day after I got a new head on it, it spun a bearing.
It's going to be fast though........
Cardomain|
Myspace
Nice Josh! I ordered my greddy kit, in a few weeks I may need your help!
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
^^^^That's the intention
. Thanks for the support guys. I really need it with as much trouble as this has been. I just got back from the parts store now. I ordered some new shifting linkage cables and TRIED to price out anew clutch but everything they had available was a little..... uhhhh..... stock(?) for what I'm trying to do here. Hopefully I will be able to find something ASAP because it is one of the only things right now keeping me from bolting the transmission up to the engine.
I can't wait to post 20psi pull videos!
Cardomain|
Myspace
Sent me a turbo for my cav......
Cody, you know I got you.
Geeds...... I hope you don't mind me doing a trunk similar to your's over the winter!?
Cardomain|
Myspace
M I N I O N wrote:Cody, you know I got you.
nah as long as u give me one of those turbos for my truck hehe
Z24 Cardomain Site ll
ZQ8 Car Domain Site
lol want a T3.....i could use a T4........
but in the spring i will be needing ur assistance.........
u will be payed greatly......
i promise
^^^^I think I'll have you guys fight to the death for a Turbonetics T-61 or something.... good small turbo for Geed's truck and Brian might see boost at 6k rpm in 3rd with his 2.2
Cardomain|
Myspace
lol..........maybe a super 60 T3....if u have one
I don't have one but I have enough turbos to pull apart that I could make one from parts.
Cardomain|
Myspace
any ball bearing turbo will do
make one then.....wonderful................i want the most beastly 2.2 out there......i have most parts....all i need is an AIC and injector holders....and you to make charge pipes....
but not doin install till spring........hoping to have a few G's to work with......so she will look good and she'll fly
how much would you want fot a turbo for a 2.2 mated to a 5 speed
the engine is stock so it wouldnt have to b to big
Damn that is one sexy/clean engine block!!
brew-san wrote:"Proper capitalization is the difference between helping your Uncle Jack off a horse and helping your uncle jack off a horse."
OK josh heres the important question.........
how soon can I come over to do mine
