Well i put the oven on to 300 degrees and let it sit for about 4.5 minutes then worked a screw driver in between the leans and worked it off.
After that i put it back in the over to try and remove all the stuff i could.
After that i sanded the whole thing down and cut and mounted the projector. I haven't mounted it but it fits inside the housing.
Remember i did this without knowing how to do it. Josh told me how to get the leans off but after that i just did what i had to do to make it fit.
Tool I used - Just bought it at lowes ( $89.99 bucks )
On baking sheet
In the process of sanding it
How it sits right now
you messed up when you sanded and painted the high beam reflector chrome part.
^^ nah, wont need high beams. plus this is just pratice cuz josh is still making mind with a hid kit so i probly won't even use these. Plus i can always sand them back down and paint chrome or something.
put rack on bottom shelf and let sit for 4.5 minutes about at 300 degrees.
It was martrix black projectors.
