lol.. fill er up, put some hot broads in and get pics!
15.1@90.34mph
Thats awsome, all you need now is Lenkos fridge with the lambo door and you're set!
I had a similar idea for underBODY leds
plasmaglow 1 color leds, etc. etc. (clickable thumbs)
A's > Twins
I'm just bitter because they beat the Sox.
lambo door on the fridge? hah got any pics of that
Thats awesome! How did you wire them up to access 110watts? (I'm no electricion, besides, down the road, I want my Type-R 12s in my house.)
^Cheap computer power supplies can be wired up quite easily. Grab an ATX supply then jumper the signal pin. As your looking at the 24 pin MB connector, with the tab up, the signal pin is the 4th in from the left. It's usually green. Jump it to a black wire, any one will due; or better yet wire it to a switch of some kind. Now all the yellow wires will supply +12v. Red are +5v, and there are other voltages available if you need any.
I have power supplies all around that will do 20+ amps of 12v continuous. That's plenty for most medium sound installations. And if you need more, wire two in parallel.
very cool idea. teal looks best imo
Predator wrote:A's > Twins
Tigers > A's
Or, a quick trip to Radio Shack to pick up an AC/DC converter (you know the kind... the big ungodly wall plugs that once you plug it in, that's all you can fit on that outlet) that puts out 12v+.  Cut off the non-outlet plug, use a digital multimeter to find out which wire is positive (usually the ground wire has a stripe), splice, heatshrink, enjoy.
