modified 2.4l for 2.3l oil pump and custom bazel - Photos & Media Forum
Monday, January 22, 2007 8:14 PM
i had the oil pan tig welded at a local collage NCC in iowa.
They did a great job on the out side very happy with it.
Iam just wondering if miller welds the inside to?
Or will this one hold fine
Also have been working on a bazel for the past couple weeks almost done have to trim where the cd player goes and sand a lil and final paint.
Also heres a link to the other pictures of the rebuild.
http://www.j-body.org/forums/read.php?f=46&i=268438&t=266055#268438
I should have my 10.5:1 comp pistons by the 31st
ill post pic then again
All comment welcome.
Thanks,
Paul
Re: modified 2.4l for 2.3l oil pump and custom bazel
Monday, January 22, 2007 8:17 PM
no I don't weld the inside of the bottom
But I do weld the inside of the other part that needs to be cut.
sig not found
Monday, January 22, 2007 8:36 PM
what part needs to be cut?????
here is a picture of the other side.
Monday, January 22, 2007 8:50 PM
so you had the pan extended ? for more oil?
Z24 Cardomain Site ll ZQ8 Car Domain Site
Monday, January 22, 2007 9:34 PM
no because the 2.3l oil pump sits lower in the pan
So in order to do the swap from the 2.4l oil pump to (2.3l no balance shaft better oiling) you need to lower the pan about and 1"
protomec
I still dont see what your talking about cutting somthing out and welding it.
Please explain??
Tuesday, January 23, 2007 12:11 AM
yeah, same thing i did, the stock 2.4 oiling system sucks balls. 2.3 ftw.
Tuesday, January 23, 2007 12:15 AM
nice.. the dash trim still needs some work but its lookin nice
SOLD....
Tuesday, January 23, 2007 5:26 AM
BOOSTED or any one else that knows thats all thats needs to be done to the pan rite no cutting anything else or welding somthing??
The dash had the lil indent in the side was there when i took it off but the edges are hidden when you install it anyway.
Sense its for me i probley wont worry about it Just sand it smooth and paint it.
Tuesday, January 23, 2007 6:45 AM
Tuesday, January 23, 2007 9:52 AM
Looks good... i will try to get some pix of my modified 2.4 oil pan tonight for ya. cant say i will be able to for sure but i can try.
Edited 1 time(s). Last edited Tuesday, January 23, 2007 9:52 AM
Tuesday, January 23, 2007 11:25 AM
does anyone else have any information on the 2.3l oil pump swap???? please fill me in!
Tuesday, January 23, 2007 12:19 PM
http://www.j-body.org/forums/read.php?f=46&i=222721&t=222721#222721
check that out, i posted some pics of the pan that protomec has done for me. you will see what else need to be cut and welded...
Tuesday, January 23, 2007 2:01 PM
if you could do that that would be great wrench monkey
Thanks,
Paul
Tuesday, January 23, 2007 2:16 PM
you LAZY!!!! lol
just check the link i have posted, there is the pics you are looking for....
Tuesday, January 23, 2007 3:24 PM
yeah i did i just wanted to see someone elses to compair but if you have any pic of the out side where its cut out on the side that would be great.
Also is yours a miller pan?
Also do you have to cut that hole in the side ??
whats it making room for?
Thanks,
Paul
Tuesday, January 23, 2007 3:39 PM
It makes room for the oil pump.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Tuesday, January 23, 2007 5:53 PM
what he said.
sig not found
Tuesday, January 23, 2007 6:20 PM
yes its a miller pan. my cam is dead and takes FOREVER to charge. ill have to go take pix tommorow
Tuesday, January 23, 2007 6:43 PM
yup, mine is a miller pan!!
Tuesday, January 23, 2007 6:55 PM
boy do i have some photos for you guys from my build. enjoy!
http://axisdevgraphics.com/2.3pump
Wednesday, January 24, 2007 5:02 PM
guess nobody wanted those photos i dug up......
Wednesday, January 24, 2007 6:23 PM
Yeah Thanks
BOOSTED
Do you have a picture of the inside of yours??
I just cut the lil side peace out and took to NCC so should have it back friday.
Also what needs to be done to the windage tray ??
Thanks,
Paul
Wednesday, January 24, 2007 6:35 PM
i just put alittle bit of sealer on the inside of mine to be safe, nothing special.
Wednesday, February 07, 2007 11:24 AM
paul have you gotten your oil pan figured out yet?
Wednesday, February 07, 2007 11:50 AM
Wasnt bazel in Austin Powers?
where are the pics of him?
http://www.j-body.org/classifieds/miscellaneous/60612/
