where do I place toyota sidemarkers if I were to do that? Is there a proper measurement or just pick a spot you like? also what two wires would I connect the yota blinkers to the stock corners, I mean what are the two coloured wires from the stock blinkers that connect to the yotas. thanks
Exterior forum thats WHERE
Here are the measurements I went from, I got them from Qwik when I did my sidemarkers.
18.25 inches from sideskirt and 6 inches from door. (to the middle of the light)
When I get home from work I can tell you which wires to tap into.
thanks wade thats where I thought I put it sorry about that
and thanks alot silver Z I would like to do this soon who knows when I can afford the actual yota fenders lol
You need to tap into the blue and black wires on the stock corners.
I also wanted the actual fenders but the cost of the fenders plus the cost of paint vs. the cost of just the lights and the couple hours it took to put them in, it was kind of a no brainer. Plus I didn't really want my fenders any wider I like the fact that my wheels are even with the outside edge of the current fenders.
And I got those measurements from Qwik and he has the yota fenders so that is where they are "supposed" to be. I thought about putting them a little lower but thought if I am gonna have them they might as well be in the right spot.
Hope that helps ya, post some pics when you get them done!
jay you and silver Z are my heros lol
nect question is how do they mount anyone have a pic of what it looks like before installing the blinker? how do I attach it do I drill holes or what?
I find it funny that people actually WANT the side markers... I was pissed the toyos have the holes so I have to have the side markers, mine don't even work, hell they don't even have buls and sockets, just empty housings to fill the hole LOL
so is it just two holes I drill or what darkstars?
I traced the hole for the sidemarkers off a Saab before I put mine on. Used a drill for the corners, a cutting wheel for the straight parts, and a metal file to shave and smooth it.
___________________________________________________________
so is that what I need to cut out of the fender?
Yep, that would be the shape of the hole you need to make in the fender. I also thought it would just be a couple holes and some screws and that was it. But once I got them I realized that was not the case! Once I had them I just measured around the light to get the size of the hole I needed. But, I did not take any pics of the process and no longer have the paper with the hole dimensions.
Qwik2k2z24 wrote:We should start a cult.
I've never been in a cult before, I"M IN!!!!
What should we call ourselves?? Silver Seduction, Mad Tyte JDM Crew.
Thats all my brain can do this early.
warped wrote:I traced the hole for the sidemarkers off a Saab before I put mine on. Used a drill for the corners, a cutting wheel for the straight parts, and a metal file to shave and smooth it.
yes thats exactally what it looks like.
Fender Post
read down to my second post. i gave silver z dimensions of the cut out. hopefully it helps you
I completely forgot that you gave me those dimensions!
Thanks
