Some of you may remember me, I'm not really active on the forums, but i do read alot.
About 2 years ago i bought all the stuff to turbo my car, now im finally getting off my lazy butt and doing it!
Here is the mod list:
Garret GT30R .63GT and .82 A/R
Custom Tubular Turbo Header
Tial 38mm Wastegate @ .6bar approx 9psi
TurboXS RFL Bov
HPTuners
Precision Turbochargers Intercooler
2.5" Custom Charge Pipes
3" Custom Intake
K&N Filter
Hosetechniques Silicon Couplers
T-bolt Clamps
GM 2 Bar Map Sensor
Screw-in IAT Sensor
3" Downpipe
3" Testpipe
3" Mandrel Bent Exhaust
QTP 3" Electric Exhaust Cut-out
Dynomax 3" Race Resonator
Dynomax 3" Super-Turbo Muffler
AEM Wideband O2 Sensor w/gauge
Areomotive LT-1 FPR
Accel 40lb Injectors w/clips
B&M Fuel Pressure Gauge (in fuel rail)
Walbro 255 In-line Fuel Pump
NGK Spark-plugs
Modded Oil Pan
B&M Short Throw Shifter
RK Sport Upper Motor Mount
RK Sport Lower Motor Mount
Prothane Front Trans Mount
Prothane Rear Trans Mount
All i have left is to finish the turbo header, now on to the pics
The Car:
My Weapons of Choice:
pepsi, it does a body good.
How the car sits:
good stuff. car should move pretty well. just dont go crazy
Blew it up, build numbers coming soon
Go crazy.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Skilz10179 wrote:Go crazy.
x2
Getting "better built" for the '08...
boom
gonna make a nice sleeper
few ?'s will you still pass your emissions out there? also, car needs a drop hardcore.
GT30R + stock motor... it'll be fun while it lasts
^^Exactly
Also, i see why you went with a .6 bar.. 9psi.. Anymore than that motor goes boom.. I just got me a 1bar spring for my 44mm wastegate... I had a 10psi spring in there and I was limited to my 10 psi kinda..
Build that motor up and have some fun with it
2012 numbers - 4SPD
AUTOMATIC!!
Stock for about a month, i'm building a motor in my garage. It will probably all come together about the same time.
Head:
1mm over ferrea valves -sodium filled
ferrea valvle springs
comp cams turbo grind
gm adj cam gears
titanium retainers
ported and polished i/e
Bottom End
.060 over JE pistions @ 9.0:1 w/ spiral lock wrist pins
2.4L Ecotec Stock Crank
2.4L Manley Rods - Custom
Cleavite77 Bearings
Balance shaft delete
Block studs to head
Block Studs to main girdle
Cometic MLS head gasket
Balanced and Blueprinted by JMS Race Engines
Fluid Dampner Harmonic balancer
Ignition:
MSD DIS-4 HO
Total approx displacement 2.5L
Approx RPM max out 8500 RPM (What they are balancing it upto)
Trans:
Quaife LSD
I also have a 5spd out of a Cobalt SS/SC, going to see if i can pull the gears out and make a close ratio 5spd.
Spec STG 3+ Clutch
Fidanza Flywheel
Driveshaftshop Custom Axles
Other goodies in the future:
Greddy Boost Controller/ Turbo Timer
NX 150hp Direct Port Injection
72lb/hr Injectors
20+lbs boost
... too many to list.
I didnt want to give away all my secrets, but there it is.
And yes emissions here suck, probably the most strict in nation. Thats why i have another junkyard motor and trans with 28k on it (got both of them for $200 total at pick-a-part) =)
By the way, i know. I Spent ALOT of money. Total amount spent thus far with the turbo
$10,500
Good stuff.
that sounds like a pretty badass setup to me
www.driftnamiperformance.com
I love what your doing w/ the cav, i really do don't get me wrong but unless i missed it your going to need more then HPT to tune the car if your using a LE5 crank because of the ring on the crank being a different number.
I want to run the AEM stand alone, so i have to find a way to set up a cam trigger, looks like my power steering might hit the garbage can.
Looks good, can't wait to see the engine setup finished. I've never heard of that brand of rims, but they look really nice. I just checked out more of their styles of wheels and they all look pretty good really.
reminds me of darkstars GTC.
got some sweet wor goin on there man
Member of J-body of Michigan.
I think he might have forgotten the k...work...I could be wrong though
14.330 @ 96.37mph
I don't think the off-the-shelf comp cams turbo grind will continue to make power all the way to 8500rpm, but its nice to know you can rev there if you want to. Not that you'll need to with ~2.5L of displacement, a tubular manifold and a gt30...
If you manage to complete everything on your list, I do believe this will be the most insane eco build by an org member...I'm most intrigued by the LE5 crank!
Nice build man..you know your stuff..keep going make it fast! 11's!! I may have missed it..I saw you had all the mounts..but what about a suspension setup..ognna have to be a good one to get that power to the ground. Keep it up man
